After eliminating variables, it appears as though my Warn 9.5XP may be what's been causing my battery to go dead in less than two weeks. If I leave the winch attached, directly, to the battery, after two weeks the battery voltage drops to 10.2 volts. If I disconnect just the winch the battery voltage will read 13.2 to 13.4 volts after two weeks. What should I be looking for here? If it helps, the connections are all clean and solid, using the Warn supplied cables.
