Hey guys, I've battled a parasitic battery drain on my jeep for years. I've just put up with it because it wasn't that bad, and I had the tools to jump it at home as well as when I was out and about. Well, a week or so ago, I went to a car show/cruise, and it wouldn't start after I had it parked and had charged the battery. I purchase a new battery and decided to get to the bottom of this battery issue. I checked the alternator, and it is running just fine. So I tested the drain on the battery and found it to be only 52 milliamps. According to my google searches, that is pretty much exactly normal.
I got one of my trickle charges out, confirmed it puts out more than that, and hooked it up. I THINK I just had a bad battery. Problem solved.
However, because I like to double check my work, I thought I'd ask you guys if you have tested this on your TJ's???? And what are you getting for a parasitic drain??
...they will always pull some power with the radio memory etc...
