Parking brake allows play in one wheel
Brian.souhan
Lifetime Supporting Member
Bethesda, MD
Ok, initial search didn’t find this, but after replacing the parking brake equalizer bracket, and adjusting them, I noticed that the driver side wheel is locked tight with no movement when engaged, but passenger side is allowing just a little movement back and forth of the wheel before stopping it tight. After wiggling wheel back and forth I can see that the adjuster but is moving forward and back with the wheel…did something come loose…hate to have to take axle out again to fix!
From what I can tell it is working fine, engaging and disengaging well, it’s just the bit of play in passenger side rear wheel that bothers me.
Any help appreciated!
Thanks!
I think he has discs.
