I don't have an oil change guy nor do I have constant tension clamps on my transmission hoses.
Whoops, quoted the wrong guy …
Even if someone DID know, it’s best to measure the installed diameter of the hose and buy the appropriate clamp. The size of the clamp indicates its nominal diameter in mm. Takes 2 seconds for you to measure with cheepie caliper gauge. Have your oil change guy measure for you at yoy next Jiffy Lube appoitment
That's pretty funny, I'm my oil change guy. Was hoping someone would know offhand, no reason to get shitty.
Has anyone been able to just get the constant tension clamps from NAPA or some other parts place or is it really only an online order thing?
My TJ came with a worm gear clamp on the upper rad hose and I’d like to replace it with a constant tension clamp.
I've seen them at my local Advance Auto Parts stores. I don't know the sizes, just happen to see them hanging when I was walking down the aisle recently.
O’Reillys has Dorman clamps. I had to do the conversion but think this is correct. 42 mm is Dorman 14086. 47 is 14087. 55 is 14088. 24 is 14083 and 27 is 14183. When I get them installed I’ll reply on here how it went. If someone looks this up and figures out I don’t know what I’m talking about please reply.
Seems reasonable enough to me.
One note I would add to the thread in general....don't try to fudge the size even by 1mm due to one being more easily available. Somehow I ordered 47s and ended up with 46s without noticing until 2 years after buying them when I finally went to install. I eventually got them on but it was a royal PITA.
Intersting, I called local O'Reillys a year or so ago and they didn't carry them. They guy knew what I was talking about so I feel like it was not a mistake.
That’s not really true, they have a specified range, the number on the tab of the clamp states the clamps nominal diameter. The larger clamps have a pretty wide range. I measured my installed diameter of the hose and measured the appropriate clamps. I think it’s 42, 42, 47 and 58. Coincidentally my old corvette used the same sizes, also uses the same thermostat. Life’s happy little coincidences …
Should be super easy to get if those are correct.
How did you go about the conversion?
Also do you actually have the clamps already and are they marked with the correct numbers?
I picked up the clamps today and wanted to run this by you. One of the hoses is a Gates 22900. On O’Reillys site it’s listed at 1 13/16 ID on one end. With a caliper it’s approx. 2 1/4 OD. Clamp 14088 specs 2-2.25 inches ID. Clamp 14087 is 1 3/4 - 2 inches. Would you go with the smaller clamp? That’s what I’m thinking since the larger one would be at the max outer range. Or the larger one?
Do the Dorman clamps have the number stamped on them like the OE clamps shown in the original post do? I’d go with whatever matches that.
