For personal reasons, I stored my Jeep for over a year and put zero miles on it. Before storing it, I had taken it to a supposedly reputable shop for a 4 wheel alignment. After the alignment I basically brought the vehicle home and tucked it away in the garage.
About 4 weeks ago I put it back on the road, but immediately noticed a popping sound originating from the front end. Spending several hours trying to chase down the problem resulted in nothing but frustration. Then, I happened upon the culprit while doing routine maintenance.
Apparently, when the technician did the alignment, using the double adjustable control arms (which I paid extra for), he induced spring bind on the passenger side, by pushing the spring against the front part of the spring/shock tower (seen in the 1st picture). Oddly, the driver side is fine though (seen in the 2nd picture).
Today I got under the Jeep and took some measurements and here's what I found.
Front Pinion Angle 6°
Front Driveshaft Angle 10.5°
Passenger Side Caster 8.5°
Driver Side Caster 9.5°
Obviously, I need to reset the front pinion angle, to get the pinion and driveshaft numbers in alignment. My question/assumption is that as I lengthen the upper arms, my caster numbers will come down, which will also move the spring backwards enough to clear the tower.
Have I got this correct? Also, is it unusual for the two caster numbers to be so far off? I realize these are rough measurements, but I was consistent in how I acquired them.
FWIW, I'm running the following:
- 4" lift
- 35" tires
- Warn Lockout Hubs
Passenger Side
Driver Side
- 4" lift
- 35" tires
- Warn Lockout Hubs
Passenger Side
Driver Side
