Passenger side turn signal DRL is on but not the driver side
Mbethel
The Bahamas
Why would the passenger side turning signal illuminate when the headlights are turned on but not the driver side ? Both turning signals work, so it cant be the bulb. Can the driver side harness be bad or maybe one of the 3 wires that connects to the harness ? Any advice would be appreciated.
Update:
I swapped the bulbs. But driver side still would not light up. Then i swapped the sockets and the driver side lit up but the passenger side didnt. So i ordered a 95023L socket off amazon for about $11 to replace the bad one on the jeep. I hope this helps someone in the future. 🙏
Reactions: Chris and Vasq
I had this issue on my 01, all I had to do was disconnect the harness and clean off the 3 metal pins with electronic parts cleaner and some sandpaper and it fixed my issue. Hopefully this helps!
Update:
Very good info and thanks for the update. Hopefully this will help someone in the future (y)
