Pekacz’s 2000 Jeep Wrangler Sport
Pekacz
Poland
Hello
My name is Mateusz I’m from Warsaw Poland. I want to share with you guys my new ride Jeep Wrangler TJ 4.0 Sport in Solar Yellow Color 106k miles on it. I bought it in December and till today I change some things. Jeep came to Poland from Canada 10 years ago.
When I bought it it was almost stock version only with a small lift.
First I renew all fenders and hardtop, after I change stock wheels for steel Mangels 15x8 and BFG AT tires 31x10,5x15 because original were too small.
Here I want to show everybody how I try to change my Jeep for a perfect weekly ride.
Thanks for your support
Great looking TJ, love the yellow too!
I'll bet that thing turns a lot of heads in Poland, huh?
Looks great! The wheels make a huge difference. So you are on stock suspension, just upgraded to the new tires and 15x8 wheels?
I need to check this, but last owner change some suspension parts and mechanic said that suspension is about 1,5 inch higher than stock. And it could be a truth because I check door level from the ground on this tires and it was close to my friend Jeep with 2 inch lift on the same wheels. So I suppose that it’s not stock. Soon I will go to 4x4 mechanic and we will check everything.
Reactions: TJ_T and JMT
You can do all that yourself with the people and frequently asked questions on here. A TJ is easy to work on.
For example, just measure your front springs and any spacer, but not the coil spring isolator, stock is 12”, anything over that is your true lift. Do same for the rear, but stock is 8”.
Love solar yellow TJ’s!
Reactions: jimsmith29841
