Soooo....driving around in my 1997 Wrangler TJ and my pinion bearing came apart....very messy inside.....Took it apart and both the ring gear and pinion gear are marked up.....cleaned it all out, put new pinion bearing it it cause I have to be able to move it and she works but has a growl.....
Question is...Mine is a dana 35...I counted the pinion and it has 14 teeth...counted the ring and forgot to write it down but after I count them again....can i take any dana 35 pumpkin (meaning ring gear assembly ) and pinion from like a Cherokee with the same ratio and put it in my axle housing?
