Hi Greetings from Sunny Italy, I have had my TJ for 15 years and replaced most things, the old girl has had a hard, hard life, I keep her going the best I can, but I am a little stumped on this.
I was driving up my forest road and the engine stopped, tried all the usual things and this is where I am:
1. Engine has spark, when primed with fuel - starts and then stops when fuel used.
2. No petrol in fuel rail
3. Pulled Fuel pump from tank - works fine on bench (replaced 12 months ago)
4. ASD relay clicking and supplying power
5. Fuel pump relay has power - but does not click, but when I short the common and earth with a jumper - the fuel pump runs ok.
6. All sensors (CPS etc) all check in limits and seem to be working fine.
So I obviously suspect the ECU (But would the ignition fire if the ECU was U/S?), or a wiring issue - is there any check I can make in the Relay holder?
I have swapped all the relays - no click when in the fuel pump position!!
Any pointers would be appreciated as I have to walk out of our farm 2 Miles a day every time we need to get into town!
Thanks for your help!
