Hey guys, looking to do a poor mans stroker build on my 02 TJ 4.0. Gonna get the Newcomer Racing 4.2 3.895" crank, some stock ratio 1.6 ratio roller rockers, clearwater replacement stock head, replace my 24lb injectors with some new ones, Fel-Pro 530SD, will be getting the rotating assembly balanced at a machine shop, see if they think I need oversized pistons(it has 140k on the motor), and wondering if I can just use my stock rods? Also what bearings should I get for the rods? Also what else needs to be changed? If anything please provide links. Thanks!
