It depends on the loads involved. Blind (pop) rivets are okay for moderate loads, but can tear out under high loads. Any torsion or large tension force is generally not good for rivets. Shear force and compressive forces are fine.
If you have access to both sides of the metal, solid rivets would be a stronger choice. Though they take a lot more skill to install.
It also depends upon the thickness of the base and attached metal. Thin sheet metal could tear out easily. Thicker plates could work well.
In addition, most blind rivets are not watertight. (Solid rivets usually are.) So if it is going on exterior metal, they will need to be sealed somehow.
