Posi-traction and leaky rear wheel bearing
woodmaster58
weston ct
Hi everyone
I have an 06 TJ LJ with posi traction rear axle, besides the noise from the clutch pack (which am ignoring) I have a persistent right rear seal leak
Twice I have replaced the seal and it still drips
Is a worn clutch pack causing the axle seal to leak?
Thanks
Or it's not still leaking and you are seeing residual oil left in the axel tube from the original leak running out. It takes a while unless you pulled a rag through during your previous repair.
Thanks for the reply, I had the bearing replaced by my mechanic so don't really know what he did but I certainty trust him.
where is the bearing any, at the wheel or closer to the diff.
thanks
