Two weeks ago I determined after a full weekend of researching online that the reason my head lights wouldn't turn on was the multiswitch was bad. I picked one up from O'Reillys here in town and installed it. Things worked great other than a) if my fog lights were in the "on" position when I turned the headlights on then the fog lights wouldn't turn on until I put them and the headlights back to the "off" positions, and b) the indicator light for my high beams would always be about half lit. No biggy as I normally don't use my fog lights and haven't been out and around where I would need the headlights other than a few times since then and they worked.
That brings me to tonight. Was getting dark with low visibility even in town due to winter weather so I turned on my headlights, then my fog lights. Everything looked normal on the dash and I confirmed by exiting the Jeep that all the lights were on and functioning. Drove around for about half an hour, then stopped at the gas station. Shut the fog lights off, then the head lights, then the engine. Was in the gas station for about 10 minutes. Started up the Jeep, pulled out the knob for the head lights, the high beam indicator on the dash was fully lit, no head lights at all. Checked the switch and the brights weren't even in the "on" position. Moved them to the "flash" and then the "on" positions but the indicator would not turn off nor would the head lights come back on. Pushed the knob all the way in, pulled it to the middle position and was able to turn on my fog lights. Seeing as it was only about 3 blocks from my house I drove home with the fog lights as my main source of illumination. Confirmed running lights, blinkers, brake lights worked when I got home. Shut everything down, waited five minutes, turned the Jeep back on, and still no head lights and the high beam indicator is fully lit on the dash.
Any ideas?
I'm leaning toward the multiswitch I bought went bad, or somehow my fog lights are causing an issue? Should probably mention the fog lights switch is on the panel above the ash tray/under the radio and was there when I purchased my Jeep from the PO.
I have no problem buying a MOPAR multiswitch, but before I do that I want to make sure there might not be an underlying issue elsewhere that is causing this problem. Any suggestions or assistance is greatly appreciated. I just want to get my TJ back to being functional and road worthy.
Any ideas?
