Snadler Member Joined Jan 15, 2019 Messages 59 Location Alachua, Fl Feb 17, 2019 #1 I am thinking of adding a power inverter roughly 2000 watt. Any suggestions from the experts the best place to put it and best way to add large wires to my already full battery terminals?
RussTJ TJ Enthusiast Supporting Member Joined Nov 22, 2017 Messages 547 Location Bridgewater, MA, USA Feb 17, 2019 #2 You might want to add a pic of your current battery setup. Then people will be able to make some suggestions.
T T Crawford TJ Enthusiast Joined Feb 4, 2017 Messages 718 Location PNW Feb 17, 2019 #3 What are you planning on running that takes that many watts
OP Snadler Member Joined Jan 15, 2019 Messages 59 Location Alachua, Fl Feb 17, 2019 #4 T Crawford said: What are you planning on running that takes that many watts Click to expand... Circular saw at times and a few other items. Saw is 1350 Watt. I also want the option of using the TJ during power failures. Last edited: Feb 17, 2019
OP Snadler Member Joined Jan 15, 2019 Messages 59 Location Alachua, Fl Feb 17, 2019 #5 RussTJ said: You might want to add a pic of your current battery setup. Then people will be able to make some suggestions. Click to expand... Should have thought of that!
RussTJ TJ Enthusiast Supporting Member Joined Nov 22, 2017 Messages 547 Location Bridgewater, MA, USA Feb 17, 2019 #6 I know some forum members have installed military battery terminals and others use additional fuse panels to feed their mods.
