Hello,
I've had some issue's, hoping someone here may have a solution. So I recently upgraded my speakers, head unit with an amp and subwoofer on my 2001 Jeep Wrangler sport. I connected all the wires where they are to suppose to go, but the head unit wasn't getting power, well it was lighting up but wouldn't turn on. There was also a clicking sound which I later found out was some electrical relay that was located behind the front left speaker (driver side) it would start clicking when I turned the key and would not stop. I then tried putting the accessory wire to the cigarette lighter and that worked but now when I turned off the Jeep the clicking would start. Weird thing is when I twisted the accessory cable to the power cable it had power and the clicking went away but the radio would not turn off. I did a quick fix and added a kill-switch to turn the radio on and off but I really don't like that, I can't save my presets. Has anyone had this issue with the electrical relay, if so how did you fix the issue. Im guessing because the sport came with a factory amp and subwoofer which I removed that there maybe be some power issue.
Thanks for the advice in advance!
