2004 - 50k miles, 4.0
So I am getting an intermittent CEL for TPS circuit low voltage. Confirmed myself as voltage is on the low side of normal even when not throwing a CEL. Figure the TPS is on its way out of here.
I have the TPS on order and heave a new Fel Pro throttle body gasket. Just wondering, if it were you, while messing around in that area, would you proactively change the IAC, MAP sensor or any other sensors (with Mopar of course)? Other than the intermittent CEL, the only symptoms it has are a fairly low (500 rpm) idle after warm up. I have already used cleaner in the throttle body/IAC
