Problems shifting gears on 2000 TJ 4.0
Gttown
Florida
I am having some problems changing gears on my 2000 4.0 TJ. I live in Florida and was wondering if draining out the tranny fluid and replacing it with synchromesh is advisable? If so what is the best brand to go with to get a little more life out of my transmission?
Paul Land
New Jersey
I did that, Fluid change worked for a few days then same. You will need a Clutch Job or if automatic new rebuilt tranny.
Gttown
Gttown
Florida
It’s a 2000 TJ standard. I was thinking of changing the fluids first to see if there is any improvement. I’m not sure if synchromesh or 10w30 is the way to go. If it is just the clutch not the end of the world.
wraith1516
Michigan, USA
in a manual transmission in a jeep it calls for 75/90 GL3 if you use a gl5 it will eat syncros (want to guess how i know this)saving 4bucks a quart wound up costing me $900ish
Flivver250
Dubai/Florida
+2 on the Red Line. It is expensive oil, but cheap oil costs more and gains you nothing. I had to stubbornly do it wrong before I did it right.
