Oh nice, is it a mechanical lift pump on the block?
Do you have a return as well? I've never modified a mechanical diesel injection system, but common rails have fuel returns, which aren't a big deal unless it's not there. Modding the tank is pretty simple for your pickup. If you are just bypassing the pump, a lot of the guys around at work are all about the sump kits. It's a pretty straightforward idea on a truck, but Jeep and skid plates is a bit annoying.
I assume you'll need 3/8" hose for fuel delivery once you're up and running where you want to be, so you may want to not mess with your fuel pump exactly and just drop a tube down there to be just a 1/2" (maybe more) or something off the bottom. I guess the XJ guys already have that figured out though.
Something that's been mentioned by the Cummins guys is not to use some of the pre filters in the tank. They said they tend to gum up after awhile and they've had to drop tanks to remove the filters later on.
What exactly was the deal with your doubler? I may have missed it. I had the NCAA tournament on in the background while I watched your last couple of videos.
