What does that engine weigh by the way? Not sure if I missed that or not.
Looks like it's coming along nicely!
About 514 lbs dry, depending on accessories.What does that engine weigh by the way? Not sure if I missed that or not.
Great progress. Just subscribed to your youtube channel. I'm swapping a V2203 into a 2A with TH350 behind it.
How does that compare to a 4.0? Not even sure what a 4.0 weighs to be honest.
Good bloody grief that's simple! Outstanding, thanks for the pictures. I'm a visual kind of guy.
I've been reading everything I can find on Kubota into Jeep conversions, and the results always seem to be universally outstanding. No appreciable downside on the freeway other than a slightly decreased top speed, and outstanding performance off road. No issues just putting around either. No reports of broken drive train parts.
The more I research, the more desirable this swap looks for a broad range of Jeep drivers.
I didn't realize you had so much of your build on way so far. I'm loving your build. I'm not caught up on your YouTube videos yet, but I'm certainly trying to binge them. And I need to get my build stuff on YouTube as well. I think it's funny that on these builds that once you get everything you think you need, it seems like you're constantly waiting on parts. I was foaming at the mouth at times waiting for parts.
I would suggest a 1" BL too while you're doing everything.
There's so much front/back room for the TJ. I love moving the engine forward and making room for the doubler. I wish I could do that so much, but I'm going to be stuck with an Atlas one of these days when I can save up. BTW I think crawl ratio isn't just your Tcase ratio, but your 1st gear and gear ratio as well. And what stinks with the diesel builds is that your gear ratio is going to be very low numerically. Your stuff will be awesome though with your doubler. I don't have much rocks that I regularly do so the 5:1 should be ok for my needs without going to the 4 speed Atlas, which looks very complicated from what I've seen.
For your more dedicated family overlanding build, if you wanna go cheap, the ZJs are pretty comparable to the JKUs. At one point I was going to pick up a JKU, but just couldn't bring myself to go through with it, by going to very similar dimensioned vehicles and replacing a 5.2 V8 with a 3.8 V6 just didn't make sense. Tires are a problem for ZJs though, it gets complicated fitting over 31" or 32" tires.
I'm really wanting a Kubota now. I've been wanting to do a 4x4 minivan with 3rd row seating one day, maybe I can figure something out. There are 4x4 Mercedes Sprinters that are awesome, but they're just so expensive and 4x4 is only part of the battle when you're off-road.
For a 4x4 vehicle, diesel really starts to shine. The OEMs are able to kinda hack together some pretty good gas based systems, but partly that's just because the plan isn't to make the vehicle last forever. Also for high HP, which is great for sales, diesel has the problem of producing insane amounts of torque which gets insanely expensive to keep things from breaking.
A mechanical diesel injection is a thing of beauty, but with emissions and flexibility of the RPM range and a few other instances common rail is kinda king for OEMs. I flip flop between the two of what I really like. The nice thing is that for oil burners both systems can hold up extremely well. Common-rail can be controlled really well with less engine compression from what I can tell, but man mechanical injection is just so simple. The only issue I could think of besides worn mechanical components is if you're adjusting your fuel to the top end of your O2 intake. Then you'll run into problems at least with different air densities.
What editing software are you using for YT? So are you building a desktop. I can't wait until you start doing the drone shots and everything that everyone does now .
Ha, I'm a Mac guy and once build a Hackintosh. I got tired of it in time and just decided to say screw it and went solely with my iMac 5K, which I don't regret at all. Yes, you pay a bit more for Apple, but it's totally worth it.
Anyways, once this thing is done, I want to know how much money you've put into it total, how many hours, and what your average MPG is. That will be very interesting to see.
I regularly turn people away from the R2.8 swaps because most don't seem to realize that once it's all said and done, you'll be into it for 25k, and if you're planning on doing it to get better fuel economy, the amount you'll spend on it will far outweigh the decreased fuel costs (unless we're talking about over a long period of time).
You may be onto something here with the Kubota swap, IF it can be done for cheap enough.
I kind of like the R2.8 but it sure ain’t cheap. Nice to think about other options. Options more inline with my wallet. Would really like to do a diesel conversion.
Yeah I'll do a build cost break down when I'm done. Admittedly I bought stuff that was not needed for the swap, so if all you are wanting to do is the Kubota engine with adapter, accessory drive/motor mount plate adapters and turbo upgrade it can be done for much cheaper.
I also realized with moving the engine around and going with a doubler setup and then I decided to go purchase a Langmuir personal CNC plasma cutting table, the cost is has risen in ways that it wouldn't normally be needed truthfully. However I bought the CNC because I have several other Jeep projects after this one which make this project seem simple in comparison.
