So I'm going to go ahead and address this now because you just brought up a great point
@BuildBreakRepeat . Initially this Wrangler is going to be SLOW. 65hp and I think 125ft/lb of torque but that torque is instant from idle. Also the fuel economy is going to probably be around 25mpg if I had to guess.
NOW before you freak out the reason for this is I don't have an intercooler installed yet and the boost from the turbo is only going to be about 4psi which is stock from Kubota. Also the fueling on the Kubota is turned down to around 30% of its maximum for insane reliability but these engines were designed to run full tilt at 2800rpm for hours on end, I won't be running anywhere near that constantly.
Once I get the intercooler installed, which I want to do after driving the TJ with the Kubota for a little bit as is to get a baseline, I'll first turn up the fuel and then adjust the wastegate to get more boost. I believe the stock turbo maxes out at around 15psi, so triple the current boost pressure.
Here is where things get interesting and I don't completely understand everything yet, but as you increase boost and have the fueling tuned for the boost you gain both HP/torque AND fuel economy. So the V2403 with NO turbo is 48hp and 118 ft/lbs of torque. At 14psi you double the stock HP and torque I believe, so your going from 48 HP to 96HP and 118 ft/lbs to 236ish ft/lb of torque right off ideal, the 4.0l doesn't make peak torque until 3200rpm.
The other thing you have to realize and what KubotaSwappers wants me to do is swap turbos, to a Borg Warner K03 which will output around 28psi of boost, and he thinks that will be around 150hp and 325 ~ 350 ft/lbs of torque again basically right off ideal.
So as I increase the boost and fueling I'll be increasing the HP and the fuel economy as well. I'm kind of hoping to get into the mid 30s for MPGs with the stock turbo truthfully, I have a K03, but I'm interested to see what the stock turbo will do.
Also you can put compound turbos on these engines for even greater HP and Torque gains, but again I'd rather go for simplicity!
*EDIT* ALSO I have an In-direct injection motor, if you get the direct injection motor you gain another 15% power on both HP and Torque, so a V2203 direct injection which are much easier to come by would have more power than my V2403 indirect injection!
Hope that all makes sense!
Thanks
Grant
