How does it drive and handle comparing it to Daves (JW) opinion on the savvy mid arm?
Will you post a link for the rear Currie antirock? Thanks.
I'm reluctant to say without adding the rear Antirock first.
There's more body roll obviously, but this is something I expected. I have never driven Dave's setup, but being as though his is not a triangulated rear and still uses a track bar, it makes sense that the roll center on his configuration is different than that of the Savvy setup.
I actually don't mind it the way it is now with no rear-sway bar. It's not off-putting in anyways, you only notice it when you go through corners, and it feels very similar to the feeling you get when you go from the factory front sway bar to an Antirock. Still planted, just a bit more body roll.
I'll give a more in dept review once I've had a chance to test it out longer and install the rear Antirock.
As for the Antitock, I got it here:
http://rover.ebay.com/rover/1/711-5...0001&campid=5337789113&icep_item=123132814947
Use coupon code PHLDAYTEN.
Having the shocks work correctly has nothing to do with being hardcore.
You're right, that was worded poorly on my part.
