Looking for a specific proportioning valve. Part # 52126173aa. This fits 06 TJs manufactured AFTER October of 2005. Called Mopar parts..no dealership in the US has one in stock. Junkyard might be my only hope.
Why are you replacing your combo valve?Looking for a specific proportioning valve. Part # 52126173aa. This fits 06 TJs manufactured AFTER October of 2005. Called Mopar parts..no dealership in the US has one in stock. Junkyard might be my only hope.
It failed. Wasn’t pressurizing brake fluid to the rears as required. Put in a new master cylinder(which was also leaking) , flushed lines first...no dice.Why are you replacing your combo valve?
Can you be more specific? The combo valve would only not send pressure to the rear if the shuttle valve was shifted by design. How did you arrive at the failure diagnosis?It failed. Wasn’t pressurizing brake fluid to the rears as required. Put in a new master cylinder(which was also leaking) , flushed lines first...no dice.
When the problem presented, was the brake light on the dash illuminated with the parking brake handle in the down position? The reason I am pressing this is I have worked on more TJ brake systems than should be legal and there is nothing in the combo valve that can fail to cause the issue as you describe it. It is a very simple device.My mechanic. I know it was the proportioning valve because I located the last one in the United States (partial sarcasm, but maybe not) on eBay...purchased it, he installed it after much trouble shooting to eliminate other mechanical issues and the problem was corrected. Now, I’m looking for another since they are obviously incredibly rare so I can have one on hand should I need another at some point in time. They don’t make that part anymore. And by “they” I mean, everyone.
