Question that always baffles the dyslexcia............going to press in a bushing upper front. froze it to get it smaller. now, the metal hole that the control arm bushing goes into, is outside an probably at the same temp as the freezer, so that hole got smaller, also, or did it get larger, from the cold? If i heat that hole up on the axle upper control arm bracket, to press in the control arm bushing, will that hole get bigger from expansion from the heat, or get smaller, since its expanding an all the metal around in the hole, will be expanding inward, making the hole smaller? so will heat an the cold make the bracket hole smaller, as the freezer will make the bushing smaller? what would be the perfect temperature for the axle bracket to be, an the perfect temperature of the bushing be, to get em to slide in with ease? any scientists out there?
did the outside of the bracket get smaller, but the inside of the hole get bigger from the cold.
