I've been getting a whistling bird singing noise from the rear diff area where the drive shaft enters it. I was told to check out the U joint and sure enough the races are pretty scared.
I bought a grease less (lifetime grease) joint from Spycer and installed it (youtube'd it to make sure)
The one thing I noticed is that it's pretty stiff to rotate. I put the caps on just enough to get the clips in and that really snugged thing up. The video did say that this can happen and to tap the yoke with a hammer to free things up and also to take a large flat punch and tap the end caps. Tapping the end caps made it tighter but after hitting the yoke a few times it moves all be it kind of stiff.
I've never replaced one before so I don't know hwo stiff it should be. I am able to take one hand and grab the exposed ends caps and swivel the joint without too much difficulty.
