Question on Rockjock sway bar links
Sean B
Winsted Connecticut
Hey there. Working on finishing up my Savvy/Rockjock lift. I got to the rear sway bar links. I am using the stock bar and the Rockjock extended links. My question is the directions say to use the stock hardware but the sizes don’t match up. The ID of the links is for a 14MM or a 9/16. The stock including holes in sway are much smaller. What did you guys do on your install? I was thinking I could swap out the sleeves from the old Rough County links but hate to do it as they are ROUGH.
Figured it out, they are supposed to be a special flange bolt. Looks like will need to get 4!
Reactions: Rickyd
