Questions about changing a NSG-370 6-Speed to an AX 15
Long Rider
dallas
My 05 Rubi had the infamous reverse problem when I bought it last year. I have an extended warranty, so I brought it to a dealership. They had to put two different re manufactured 6 speeds in it before they said it was good to go.
It was not.
It is actually worse now. I've thought about taking it back and getting the warranty company to fix it, but they delay things so much, and I've read enough to know it's a fairly lousy transmission anyway.
Lots of people on this site recommend changing to the AX 15.
Has anyone actually done it?
Have they done it with a Rubicon?
What does it entail? (Driveshafts, clutch, etc)
Any help would be greatly appreciated!
Chris
Administrator
Staff Member
San Tan Valley, AZ
My understanding is that it bolts right in without any issue at all. I could be wrong, but that's what I understand at least. Hopefully someone who has done the swap can chime in.
The AX-15 does seem to be a better choice than a replacement NSG370.
bromel
Montauk, NY
You're right that the AX-15 is a better choice, but it won't simply bolt in. Off the top of my head, the clutch disc has to be ax15 style and pressure plate has to be nsg370 style. The problem is that the flywheel position sensor is different with the late-model TJs, so you also need a new bell housing. This should be the right part:
I don't believe you'll need new driveshafts, but double check that.
bromel
Montauk, NY
Actually you should probably buy directly from Advance Adaptors as you have to specify the 05-06 configuration to get the proper bell housing with the correct flywheel sensor location.
Reactions: Long Rider
L
Long Rider
dallas
It would be foolish not to change the clutch when everything is torn down. With the transmission, bellhousing and clutch + fluids, I'm looking at $2,500, not counting bandaids and beer. Dang it!
Klutch
Massachusetts
I've had these two links bookmarked for a while regarding this as I too have an 05 rubicon with an nsg370 that is giving me issues. Going to discuss the idea with my shop in the near future, although I probably won't do anything until the end of the year since I just bought an 02 sport to be the new daily and want to do a small amount of work to that first. Would rather put something trusted in it's place instead of spending good money to fix or swap the nsg only to potentially run into more issues down the road again. Replace the ***s with wrangler forum.
https://www.***.com/f210/documenting-and-requesting-input-on-swapping-nsg370-in-2005-or-2006-tj-with-nv3550-2058697.html
https://www.***.com/f210/nsg370-to-ax15-conversion-1840642.html
L
Long Rider
dallas
I've tried to substitute *** with "wrangler forum" in practically any combination I can think of, but nothing works.
Klutch
Massachusetts
Sorry, no space between the two words (wranglerforum). I know links to a couple of the other forums are blocked because they blocked links to this forum so I wasn't sure if I typed it out normally if it would also be an issue. You could stick the url with the *s in a search engine as is and it should come up too.
