Quick clarification on Rancho RS5000X RS55241 shocks
jimstj
So Cal
Hey Everyone,
I just received a set of RS5000x shocks for my 02 TJ. As these are gas shocks the front shocks have a ziptie that needs to be cut so the gas charge can extend the shock. interestingly, the rear shocks rs55241 do not have a similar ziptie to compress the shock. the model number on the shock is correct but wanted to understand why this is the case. i was thinking both the front and rear should be compressed before installing them.
I was not able to find an installation instruction on the Rancho site so hoping someone can shed some light.
thanks guys,
Jim
Mine came with a white piece of plastic with loops on each end to compress the shock so it fit in the boxes. I compressed the shock all the way and took that off then connected one end of the shock and compressed the shock until I could connect the other end.
There were black zip ties, but those were for the shock boot if you put them on.
That's indeed strange. The set of 4 rs5000x I bought in April were all compressed and held by a white piece of plastic with loops at each end, and all 4 extended to full length when the plastic was removed.
They are gas, they should extend when not held down. Who cares how they were shipped? Press them down, if they feel okay they are okay.
thanks guys, yea that is what i ended up doing. The front were as expected and the rear I just needed to manually compress them as i was installing them.
finished and the ride is as everyone says... excellent. I had replaced RS5000s. I think i read someone said Rancho should not have given them the same name as the difference is so significant.
thanks again
