Hey all,
I'm adding an Aux Input into my stock radio with a nifty little kit i got from amazon. The plug in is easy enough as it utilizes the CD Changer 10-pin connector. My issue comes in with the yellow power wire that comes out of the interface box. The directions state, "Connect to constant 12 volt power source."
So I'm thinking to myself.. hmm why would i need to connect this to the constant power wire when I only need this to work when the jeep is on.
Based on the pinout diagram I see the wire I need would be either pin 1 or pin 12 as they are both Red/White wires and labeled as Fused B (+).
So here are the questions:
1. Why wouldn't I simply splice it to the Pink Fused Ignition Switch Output (RUN-ACC) wire?
2. If I needed to run it to the constant power Fused B (+) how would I know if I needed to splice into pin 1 or pin 12?
Here's what I picked up from amazon.
All tips, tricks, thoughts, and input are always welcome!
Thanks
-Rich
Thanks
-Rich
