Tried there but not really to helpful on making the right choice.Is the http://www.gorancho.com/ any help? They list the different lifts and models that fit for them.
Rancho lists all the compressed and extended lengths of all their shocks. Sort by vehicle and look at all the options for their "recommendations" for lift height. Pick the sizes that will actually work best for you.Tried there but not really to helpful on making the right choice.
The 5160 has what Bilstein calls "Self-adjusting deflective disc valving", which provides additional free bleed in the compression stroke.
The most common Rancho recommendations made here are for the RS5000X, not the RS9000xl.I had the exact opposite experience. When I did my lift several years ago, I installed the adjustable Rancho 9000xls right from the start based on the rave reviews they got at another forum. They were terrible on any setting. The adjustable valving was a joke. It could only make the ride stiffer, but never provided any rebound control. My Jeep would lunge upwards as it would rebound from the slightest dip. The tires would just skip across potholes. There just no rebound control. After much discussion on the forum, I finally decided to give Bilstein a try. Now I don't remember if the 5100s are valved that different than the 5160s, or if its just the remote reservoir, but the 5160s were a dream come true. The ride was silky smooth. It had similar stiffness to the Ranchos set on #2 but smoother. I also had control. The rear end would now stay in place and it did not bounce across every pothole. When rebounding, the rear end would return to its normal ride position without the drama of the 9000xl. Everything was just controlled the way it should be. Offroad, I found the same thing held true. The Bilsteins simply provided control the Ranchos could not match.
So when I see threads like this I am always amazed. I don't know if its due to a difference in desired handling or if its due to the difference between a light TJ vs an LJ. I wanted more controlled handling like a european sports car. The Bilstiens gave me that. If you like a floaty uncontrolled ride, then maybe the Rancho will fit you better. I have read similar experiences from others as well. So its not just me that noticed this. Whatever your preference is, you could not get me to put Ranchos on my Jeep again. Infact I still have my nearly new 9000xl just sitting around because I don't even feel right about selling them after the poor experience I had.
I guess all I'm trying to say is before you jump on the latest bandwagon, know what you want and do your research. Obviously many people like the Ranchos, but they are not for everyone.
There's no mention of an additional check valve in the 5100 that I can find on the web.That sounds familiar, is that absent in the 5100?
The common Rancho recommendations here are for the RS5000X, not the RS9000xl.
Ouch! I hope that was fixed along with the shocks.I had Bilsteins on my '91 Wrangler - got tired of stopping every 50 miles to piss blood, LOL...
If we’re shooting to find a shock that suits our needs, if you off-road a lot you’ll likely want a stiffer shock, you might love Bilstein 5100’s. If you are on-road a lot you’ll likely want a softer shock. I think the Rancho 5000X is a good middle of the road shock. They are not dreamy when driving onroad like some people have said. They may have been dreamy compared to what they ran before. They are dreamy compared to Bilstein’s or Fox. But you could probably find a softer shock, maybe even the 9000xl on it’s lightest setting. But one thing is for sure, never take advice on a good shock for our TJ’s by looking at what works on JK’s or CJ’s or any other Jeep. Look only among TJ’s. My vote is against Pro-Comp Shocks @Billwynburger. Why not just go with what is tried and true. There are a couple more options you could look at, but not Pro-Comp. And IF money is an issue, why not just get the RAncho 5000X which are valved very well for our TJ’s?
LMFAO thanks for the visual! I even laughed out loud and got that funky look from my husband. You know, the look of are you ok...I had Bilsteins on my '91 Wrangler - got tired of stopping every 50 miles to piss blood, LOL...
