Regear is scheduled for mid-March, so I need to make a decision.
Note: The stub shafts in Yukon's 30-spline hub kit only allow for the stock 5-760x u-joint so I can't use R&G's stronger American-made front axles or the large/stronger u-joint.
In theory, the RCV would eliminate the weak point, but I don't know if it's an actual problem since I've yet to run the setup.
I don't wish to spend $$$ fixing a problem that will never exist; however, I want to build it properly if there could legitimately be issues moving forward.
I appreciate your thoughts on this.
