Me too. Would like to know what I'm doing wrong here.
I hope you get it worked out, because I know it can be frustrating, just trying to get the Jeep right, and thinking you've done everything right and everything you know and keep searching. It's no fun when it's not working. I hope its wheels/tires.Well, I'm going to assume my pinion angles are good and move on to other possible causes. Tomorrow after work, I'm heading over to a fellow jeep buddy's place to put his wheels/tires on and take it for a spin to rule out wheels/tires.
In those pics, are the u joint straps tightened down or loose? There looks to be large gaps between them and the yoke.
Good luck with the tire and wheel swap. Hope you can get something figured out. This has got to be driving you nuts! No fun when things aren't working right.Well, I'm going to assume my pinion angles are good and move on to other possible causes. Tomorrow after work, I'm heading over to a fellow jeep buddy's place to put his wheels/tires on and take it for a spin to rule out wheels/tires.
So they are tight and have that gap? I have never seen one with gaps, they always fit flush. Not saying that is your problem, just that it should be addressed.Yes, they are cinched down tight. I bought a new strap kit when I got the new drive shaft, but I will re-visit that tomorrow.
Concerning the u-joint straps: that is not normal. I don't know where you got that kit from but I've never seen those types or bolts or straps so short like that. I would go to the parts store and buy the regular strap and bolt kit from behind the counter and install those. Not that it'll fix the problem, but those should not be installed like they are in your pictures.
Did you ever swap out the tires with your buddies jeep? I am kind of agreeing with Chris's original reply. Maybe when they did the swap they lost a wheel weight? It sure sounds like tires to me. Again it is hard to diagnose over the internet, but swapping tires with your buddy is a free test, and pretty easy too if you have air tools. At least a cheap easy way to rule something out. Another test is that you feel like it is coming from the rear. Try rotating your tires, and see if you can feel it in the front.
I don't want to talk trash on Adams shafts, but here is one thing I'll say...I have had issues with mine in my YJ. My first one was balanced imperfectly slightly and so about 40-55 or so it would vibrate noticeably. It got a little better at highway speed but still not perfect.
Now, James has outstanding customer service and got me another shaft like he got you (I think I remember you saying that). That one worked well for me at first, but it did have a slight vibration at 75-80 out of the box. I typically cruise at 75 here on Texas highways so it was noticeable for me. I decided to live with it, they were better than my vibes had ever been.
I recently moved to Dallas (3.5 hours away from where I was previously, in College Station). The day before I moved, I drove both ways to do some stuff for my new apartment. That's about 450-475 miles of driving. The Jeep performed pretty great considering the distance and the fact that the vibes were easily not a big enough deal to be on my mind. Then, the next day, I removed my driveshaft (liability purposes though U-Haul) to tow the Jeep back out to Dallas on a U-Haul dolly.
Ever since that day, I have had horrible vibrations from 40+. You can hear the u-joints humming easily. I don't even have my front shaft installed and they don't spin on YJs anyways so I know it's something with my Adams shaft. Who knows why, nothing changed with that shaft but now it's giving me issues. The u-joint caps were taped tight and the driveshaft was gently carried in my mom's car. I have rotated the u-joint positions on both yokes separately so the shaft has been reinstalled in every possible way that it can be.
I don't want to really bother him for another shaft, I'm strongly considering going to Tom Wood and just buying one from him. It surprises me because so many people have great experiences with Adams but for some reason, I haven't. Just something to think about.
Maybe find a TJ or YJ buddy around you (with an SYE, of course) and steal their CV shaft for a few minutes just to see what happens. I don't really know what else to tell you, I'm at a loss.
I should add...4.0, 5-speed AX15, 31's, 4.10 gears. I'm geared basically the same as your 4.56 and 33's.
