You will need to let me drive your TJ up to 55-65 mpg @bobthetj03 on the Cow run. Just to witness the vibes
Harmonic vibrations can be a real bitch to solve. Reminds me of when the Harley aftermarket first came out with a 6 speed tranny for rubber mounted FL frames. They worked perfectly but had a harmonic drone that was unacceptable. They finally figured it out but I never heard what solved the problem.
It makes me wonder why Jeep had to add a harmonic balancer at the end of the TC output shaft. I had to remove it to install the SYE.
Please do. I'm sure most of you think I'm just being super anal and it's just a jeep for heck sake. Deal with it, right?
Not at all. I have been there and even small sounds that can be muted by a radio will drive me insane in a daily driver. I guess its the OCD in me but I 100% understand where you are coming from.Please do. I'm sure most of you think I'm just being super anal and it's just a jeep for heck sake. Deal with it, right?
Pretty sure they changed to a helical gear cut in 2010 that finally solved the problem.
But the vibes came after the regear, before the SYE. I still think it’s something in the gearsIt makes me wonder why Jeep had to add a harmonic balancer at the end of the TC output shaft. I had to remove it to install the SYE.
What I’m saying is I have read through this thread, 10-15 other threads on this forum, countless other threads on other forums, spoke to half a dozen people or so at different Jeep events. Have driven in three different Jeeps in my area in local Jeep clubs that all have this vibration. There appears to be a few things in common from my observation. They all have 4:56 gears or lower, 33 in or so tires, and the 4 speed auto. I personally have not spoken to or heard of anyone with this issue with a stick, 3 speed auto, or anyone running a 35 in or larger tire.
Damn Bob, I didn't realize until just now that you have been chasing down this problem for over a year now! I can only imagine your frustration. FWIW, all the hell that I went through this last 7 months in performing my Jeep's excorcism, I have a light vibe between 25-35mph now
This month makes it 2 years I've been chasing this debil! Finding out some interesting results though with all these pinion angle changes. Just went full retard and sucked the pinion down to -6.0*. Stay tuned.
@bobthetj03 - it still vibrates with one of the shafts out too, correct?
Adjusted the front pinion tonight. Lengthened the uppers and have the pinion 1.0* higher than the front DS. No change.
