Re-gearing: what size gears?
Responce back,
Sorry Dan, the lowest ratio that motive makes for that setup is a 4.88. We can switch to Yukon's. Here is an updated quote. Be advised for most tj/lj applications we recommend a 5.13 for a 37" tire. Also be advised that the pinion in a 5.13 is very small and therefore not as strong.
Responce back,
4wheelparts is the Kmart equivalent for the off-road world. Find an independent shop that can source Revolution Gear and Axle ring and pinion.
1:13 PM (1 minute ago)
This is what 4WD parts told me.
Dan, the lowest ratio available for that diff is 4.88.
Is this accurate?
It was the only choice 15 years ago when I did mine. Revolution, Sierra and Yukon all offer 5.13. Walk away from four wheel whores and try to find a reputable shop that will work with you.
Hi there, I just got an 06 SE 2.4l 6 speed manual with 3.73 ratio, which gear ratio would be better to use if I want to go with 33s tires 4.88 or 5.13?
Thanks!
Reactions: pbeach
Thanks!
My '06 TJ, 2.4L on 33s...
FWIW, I upgraded two years ago:
Yukon Gear & Axle Front & Rear Ring and Pinion kit - Dana 30 Front / Dana 35 Rear - 4.56 gear ratio (from 3.73)
Part # YGK005
www.yukongear.com/shop/ygk005
EATON 912A569 Trutrac Limited Slip Differential for 27 Spline Dana 35 Axle with 3.54
Part # 912A569
https://www.eaton.com/us/en-us/skuPage.912A569.html
Thanks to @Jerry Bransford 's direction: at 4.56, the fun returned — a noticeable performance boost for the dinky 2.4L. Essentially, I'm one gear higher throughout the range - highway: used to be at 2400+- RPMs in 5th @, say, 55-60mph — I'm now comfortably cruising in 6th, 2400+- RPMs @ 65mph. Before, I often enough wouldn't see 6th on the highway because I never had the power to maintain, especially into the wind or uphill.
Part # YGK005
Part # 912A569
Thanks for the info!
Reactions: pbeach
