Tyrone
They are bright! I saw someone installed a light above the brake light and just wired them in. That looked like a good idea. The factory ones are so dull I can’t see a damn thing.
These are the LEDs I used in the photos above if anyone is looking for them. There's a thousand + search results for "1156 LED" on Amazon
https://www.amazon.com/dp/B0721FNCWP/?tag=wranglerorg-20
What did you find on eBay?Can anyone point me in the direction of where to find some of those 41mm cones? A quick Google search isn't finding me much.
Sweet... those are the same ones that got delivered today. Can’t wait to try them.
All sorts of random-ness, ha ha. Is the 41mm the length of the reflector or the diameter?What did you find on eBay?
@jjvw nice job! It's funny, for the past 2-3 weeks or so, I've been meaning to sit down and think up a way to do just that. Well, not that exactly, but to beef up my reverse lights while keeping it contained in the OE housing. I like how you went about it. I can't imagine the light getting anymore focused than that! Well done.
I always like seeing diy projects like this.
For making my brake and running lights brighter I lined the bulb housing with high intensity reflective sheeting like what is used on traffic signs. Not as good as the led bulbs I suppose, bit worked well for me. You can probably get scarp pieces from a sign shop for free.
I have had something similar to these in the JKU as well as the Audis and the difference is great. Plus no flickering.I used this it just plugged straight it like a normal bayonet fitting bulb...Huge difference when I'm backing up.
Reminds me of the New England corridor once you go past Connecticut. It becomes the fast and the angry real quick.I won't do this. But I've always wanted a switch for my backup lights. So I can flash drivers that ride my ass at 80 mph on LA freeways.
Usually they are racing someone. Or just being an a**hole. I can't tell you how dangerous it is driving on LA freeways sometimes. People literally race at over 100 mph. Often travelling in packs of 3 or more. And no I don't do 40 in the fast lane. This is in all other lanes. It's crazy. Makes you feel very unsafe. When these a**hats pull up on your rear at a 110 mph and then stop within inches of your bumper. While your doing the flow of traffic at 80. And then ride your a** until they can find a way to dangerously cut in front of you.
I don't do 80 in my Jeep. In my Jeep I stay in the slow lane at 65 or 70. LA traffic has been listed as the worst in the US for a few years now. It used to be NY.
Maybe doing this on surface streets at slower speeds would be ok. But I would never do it. Just always wish I had some bright lights to throw in their faces. Just to warn them of how unsafe they are being. Rant off. lol.
I have the reverse leds someplace in my garage. Was hoping to get some of my LED's installed today. Maybe I'll start with the reverse lights. If I can find them! lol.
It may be the same thing, but I put in the led bulbs and lined the entire housing including the divider with foil tape used for duct work. Then cleaned it with a little bit of chrome polish I had laying around. Super shiny surfaces inside the housings made all the brighter bulbs really bright. After driving through a gate, I set the e-brake and put it in reverse to clearly see everything easily. Same with hooking up the different trailers. Thank youMylar tape works well too.
Really appreciate this thread, thank you all. I just replaced the standard 1156 reverse bulbs with a pair of LEDs from Amazon. Very happy with the additional light when backing!
I apologize for this being a question on your older post. Did you have any issues with your turn signals not functioning properly?
I’ve done the same thing in my TJ and several other vehicles without causing any issues with turn signals or other problems. Straight LED swaps are also fine with various running lights (e.g. pick-up cab lights and most license plate lamps (not the TJ because the plate is lit by the combo brake-turn-marker bulb). I believe the flasher issue is only a created if you replace your turn signal bulbs with LED and don’t put in some sort of in line resistor. LED headlight conversions also require adapter.
