Label from a forged steel eye Bolt rated at 3K lbs. What is it used for if you follow the instructions on the label.
... Thank idiots and lawyers for that label.
Typically you must have a 4:1 saftey factor
When i used the term 4:1. I was referring to it must withstand 4 times the rated load.That's good to know. I certainly won't use one of these when I weigh over 500 lbs.
Picking nits but the typical for overhead is a 5-1 safety factor to arrive at a Working Load Limit. They could easily be strong enough to work as such but the company doesn't want to go through the testing and certification process for a bolt that doesn't need it since it is being used as a tie down point, recovery point, or anchor point.More than likely it does not meet the requirements for lifting / hanging loads. (Typically you must have a 4:1 saftey factor)
However it can be used a a tie down.
Good information. Ill remember that.Picking nits but the typical for overhead is a 5-1 safety factor to arrive at a Working Load Limit.
Better, the same rules for that eye bolt are the same ones we use for our winches. They do not have a safety factor or a working load limit because they are not to be used for overhead lifting and are not hoists. Once someone can get that into their head and understand it, they can stop collecting specifications and mixing up industry rules.Good information. Ill remember that.
