Hi, I’m looking to put a 4 bike rack on the back of my ’03 TJ. The combined weight of the rack and the bikes will be approx 170lbs (rack is 70lbs and the bikes are around 100lbs).
My understanding is that my TJ has a 2,000lb hitch rating which translates to a tongue weight rating of approximately 200lbs. Given the weight of the bikes will be sitting out from the Jeep I’m concerned that I’ll be over the tongue rating and should get a Draw-Tite hitch that is rated for 300lb or 400lbs of tongue weight.
I’d much prefer to get a new rear bumper with an integrated hitch like a Hard Rock or LoD versus the Draw-Tite. Do you think the Hard Rock or LoD would be able to support the load? I’ve spoken to both Hard Rock and LoD and they said their bumper ratings matched Jeeps but could not given me a class rating for the hitch.
I’ve got a 2” lift (Rancho shocks & BDS springs), run 31” tires and have a Warn 8000 winch. My front bumper is being upgraded to either the Hard Rock Patriot or LoD Signature so I can tow the Jeep behind an RV. I’ll check how balanced the TJ is after the rack and bikes are installed and if needed add rear airbags.
