I thought I would pick everyone’s brain on this one.
When I pulled the mid-pipe that has the rear catalytic converter on it, there is a collector with three bolts and three nuts, that holds it to the down pipe (which connects to the exhaust manifold).
Anyway, everything was so rusted, I had to take a cut-off wheel to those three nuts, so I could get the pipe off in order to install my RK Long-Arm Kit. (Currently the heads are still attached to the other side of the collector, even though I cut the Nuts off the other side).
My question is related to the bolts. Are they part of the mid-pipe/rear catalytic pipe, and can’t be replaced unless the entire cat is replaced, or can those bolts be obtained?
Thanks for your thoughts.
RC
Sent from my iPhone using Tapatalk Pro
RC
