The shaft collars are not reusable but I have used a big separator to get the bearings off. Not fun and I don't like resetting the entire shop press to put the press bed at the bottom but, it can be done. The biggest issue is supporting the splitter so you aren't trying to bend the all thread that holds them together. Difficult to sneak something in over the flange. You have to set up two supports outside the flange and then sneak two more across them to set the splitter on to get enough room over the press bed.If you figure out a way, let me know.
No reason to not take out both on Dana 44.
If you were not draining oil and tilted axle ?? He was asking about his 44.
