Alright guys so I am back with another issue. I am trying to install a rear fog lamp on my Canadian spec 03 Rubicon, without which I can't pass the inspection here in the UK. I got myself a factory EU Rear fog lamp switch (on euro TJs it is the same style switch as the rear window defroster switch, rear wiper and o/d switch if applicable). I also bought an automotive relay. I applied power to pin 2 on the switch and I hooked up pin 3 from the same comnector to pin 86 on the relay. I then applied power to pin 30 on the relay and used pin 87 to hook up the rear fog lamp. It didn't work. The fog lamp works, as I tested it separately. If you put power through pins 2 and 3 on the switch the little orange led will light up but only if you keep the button pressed and it turns off the moment you take your finger off. What Is the problem? I know for a fact that EU Jeeps use a weird green so called "Smart relay" for the rear fog lamp and I don't understand how it's supposed to work. I think either the switch only works together with the green relay... Can somebody shed some light on the matter and explain how the factory wiring is supposed to work? Why are pins 5 and 2 on the factory relay both getting power? Why is pin 3 on the switch connected to pin 4 on the smart relay and both connected to the lamp on the factory wiring?
Thank you in advance!
