Rear Passenger Side Sag
Ramona Wrangler
Ramona, Ca
After installing new coils springs, shocks, sway bay links,,,,,the passenger rear sags a tad over an inch more than the driver side. What gives? Get a 1" coil spring spacer for the passenger side?
What springs? IIRC the OME ones have an A and B side to compensate, for example.
I don't know which bushings are in your CAs, but if you didn't loosen the bolts first that could be a component as well.
Reactions: flyinfish
H&R Springs.the only thing I did different was I removed the passenger side front lower CA bolts to get the axle to drop lower to help with spring removal.
