Hey guys, I’ve got a project Jeep ive finally gotten put together and rolling around. In the rear I’m running a ford 8.8 axle, and have it stretched back around 6-8 inches, making the rear shocks almost vertical. The major issue I’m having is that the stretch has severely limited my up travel. I’ve probably got less than two inches of exposed shock shaft at ride height. Clearly I need to do something about this sooner rather than later. I know most people at this stage in their builds will usually opt for outboarding the shocks and frenching them into the frame. However, this is something I’m trying to avoid for now due to where my anti rock is setup and not having any body lift currently. In the distant future I do wish to outboard my shocks, but right now I just need to be able to drive the jeep around without busting everything up every time I hit a bump on the road.
Ive seen different options for relocation the shocks, I wish to discuss the pros and cons between some of these different options. I’ve seen people mount the shocks to the front of the axle. I’ve also seen a kit from nth degree mobility called their “shock shift kit” which seems promising, but would probably only give me 1/2-1inch of travel if I managed to shift the axle shock mount 3-6 inches outwards on the axle. Any suggestions on how I should proceed?
