Rear tire carrier suggestions?
GeorgeSully
166
South Carolina
I just got my barricade classic rear bumper and tire carrier and there’s no shaking at all even in the current hurricane winds also I love the look and it was 350 for the whole thing with free shipping on extreme terrain it was a bit of a pain to install cause some of the brackets were bent in shipping but there’s no drilling or anything needed
Chris
Administrator
Staff Member
Sep 28, 2015
34,400
Salem, Oregon
Don't waste your money on that thing. It's overpriced when compared to the Exogate / MORryde tire carrier. In addition, that one doesn't tie into the rear roll bar, so it's not as strong.
The smart thing to do would be to get the Exogate / MORryde. I have one and absolutely love it. The design behind it is better than anything on the market IMHO.
I always encourage people to stay away from rear bumpers with built in tire carriers. The good majority of them are very poorly built, and the swing away tire carrier starts to sag soon after purchase, and then become very stiff and difficult to swing open. This is due to the fact that most of them (especially the cheap Chinese ones such as Barricade, Smittybilt, EAG, etc.) use crap quality bearings (if they're even using bearings at all).
Reactions: skrelnik
Vcook
106
Chicagoland
If you have a larger than stock tire, yes. The previous owner of my jeep had already cut the wires and removed the internal connections (brake light didn't light up) so I just removed it.
JMT
The Jeep Guy
I have a 33” spare and notice the tailgate is not shutting correctly. The mount on the stock carrier seems fine. Will the exogate hinges solve this?
primetime4
45
Northern Virginia
I am really liking the Exogate suggestion. How difficult was it to install? I have a 2001 and those body screws are likely to be a challenge just judging by the 2 windshield screws I removed for a quick-detach mirror. Did you heat it with a torch? I also thought about picking up a hand impact tool and giving it a try. Any tips are appreciated. Thanks.
Jerry Bransford
TJ Guru
9,436
Escondido California
Yes. Eventually the stock carrier will likely fail under the weight of a 33" or bigger spare tire, mine cracked on top after about 6 weeks. The tailgate and its hinges are not up to a 33" or 35" tire for long.
But you can do this and eliminate the need to reinforce the hinges with the Exogate or install an aftermarket carrier. These take the spare tire's weight off the tailgate and its hinges.
Reactions: M35A2 and JMT
JeepZilla380
999
Atlanta, GA
If your hinges are tweaked from the weight of the tire, I could see the Exogate remedying that. Mine has been on for 4 years and still is rock solid. Its been carrying a 285/75r16 all that time with no issues, and its rated up to 35 inch tires.
Reactions: JMT
JeepZilla380
999
Atlanta, GA
Easy install, but if I recall correctly the instructions were close to non-existent 4 years ago. I think I had to go by pictures online at the time to get mine installed, but still not bad overall. Lots of us on here running them now, so any issues during the install, you have a big user base to lean on.
Chris
Administrator
Staff Member
Sep 28, 2015
34,400
Salem, Oregon
It's incredibly easy to install, nothing hard about it at all. No need to use an impact, torch, or anything. It's literally a straight forward and simple install!
JMT
The Jeep Guy
View attachment 55710 View attachment 55711
Ok, do you have any idea what something like this is called? I have a 2" hitch receiver built into my bumper. I'd like to do this solution till I can save the funds for an Exogate/Moryde.
