SOLD Rebuilt HP Dana 30 w/ 4.88, Dana 44 w/ 4.88 & ARB
Sea Cot
S.E. MI
Price
2800
New Boston, MI
$2800. Nearly turn-key axle setup for your next round of upgrades.
TJ Dana 44 rear end 0 miles since rebuild
LINK TO PICS
  • sandblasted housing, 2x POR-15 coats, 2x farm implement top coat
  • New Revolution 4.88s w/ Timken/Koyo install kit (pro install)
  • New ARB RD116
    • includes install manual, and unopened accessories kit w/ solenoid, switch, airline, etc. Compressor not included or available
  • New Teraflex diff cover
  • used drum hardware available, backing plates have been blasted & painted. Drums and hardware are off and have not been refreshed.
High Pinion Dana 30 0 miles since rebuild
LINK TO PICS
  • sandblasted housing, knuckles, 2x POR-15 coats, 2x farm implement top coat
  • CE-9112M Johnny Joints pressed in to control arm mounts
  • open differential for 4.88 gear set
  • New Timken unit bearings
  • New Moog upper & lower ball joints on both sides
  • New Spicer(?) u-joints
  • the spring pads had Currie CE-9122F bump stops installed that required tapping/threading for installation, I believe this to be the only "permanent" housing modification.
  • used, but good condition brake calipers w/ mounting bolts, rotors and flex hoses. No other visible permanent modifications to the housing or knuckles
HD Steering Kit, I believe it is RT Off-Road part number RT21005 w/ 1.25" diameter rods. New, open-box item.
I can pallet/crate the axles and ship at corporate rates from a business with a loading dock from zip code 48108, or drop off at a logistics terminal at DTW airport- zip code 48174. For the purposes of cost estimating, the axles would ship in a single create, dimensions 72"x36"x24" @ 550#, class 85 IIRC. Local pick up is an option.
I'll accept bank transfer, certified check, Paypal +fees, and U.S. dollars.
Reactions: JMT
I've decided to keep these for the COVID-19 home auto shop build.
The take-out LP Dana 30 & Dana 44 3.73 trac-loc will be available soon.
