I’m finally getting around to rehearing the HP Dana 30 I pulled from a 99 XJ. I’m going from the stock 3.55 to 4.56 and using Revolution gears and their master install kit. Before I press the inner bearing on, I had a question about the oil slinger. The one included in the revolution kit is significantly larger than the stock one. It also isn’t completely flat like the stock one. I tried to call them, but they’re closed until Monday. Does anyone know if this is by design? Should I reuse the stock one instead? I’m just looking for advice from anyone who has used the same install kit. Thanks.
