I am currently installing an AMP for my 2006 Jeep TJ. I cannot get the amp to turn on. I found that I am getting 0 volts from my blue/white amp turn on wire. Does anyone have any ideas why it’s not showing power? Any idea how to fix?
If this is an aftermarket radio it may not be an amp turn on wire. Some after market radios the blue/white wire is the powered antenna wire. So only will power when the radio is selected.
If there are no settings in the radio to change it what most people do is tap into the red wire off the back of the radio. That is the ignition turn on wire.
If you can please provide more info on what you actually have like a model of the device.
