Recently we had a water pump replaced on a 2004 Jeep 4.0L The next day it started misfiring on Cylinder 1. The engine never overheated and two shops agree there are no signs it overheated. The new shop is telling is the below and provided the video/photos.
Misfire is not present under load at all, only during coasting and idle conditions. Performed compression test on cyl 1 and 3. Both cylinders had close to 150 psi. Leak down test was very low. Connected a vacuum gauge to the intake manifold and monitored the vacuum. Noticed the vacuum is somewhat low at operating temp, and has consistent drops that coincide with the misfire. Suspect a valve issue is causing this condition. Likely an exhaust valve.
RECOMMENDATION- Remove head, replace valves for cylinder 1, have head machined and pressure tested, reassemble and retest.
Also, the repair cost is 1800.00. Is that normal?
PS we had already tried all the normal fixes like fuel injector, coil pack, plugs etc.
VIDEO:
VIDEO:
