2001 TJ 4 liter
I replaced my rusted-out fuel tank skid plate. While it was out I took the fuel pump out and replaced both of the strainers with new. I replaced the large round rubber gasket as well.
Put everything back together I turn the key I can hear the fuel pump come on momentarily each to pressurize but I'm not getting any gas to the engine. Wont start.
There is no fuel pressure coming out of the valve on the fuel rail either.
there is no fuel filter along the frame rail, apparently someone in the past replace the fuel line and didn't replace that.
suggestions or ideas?
the fuel pump seems to be working but no fuel is reaching the engine.
Could it be something with where the gas line connects to the fuel line coming out of the gas tank? It just pressed on with the plastic clip, does it have to go so far in as to open a little door or something in there?
do I need to bleed the air out of the fuel line somehow? Like open the fuel rail valve while someone else cranks the engine over?
Thanks
Sent from my XT1575 using Tapatalk
Thanks
