T Crawford
Not sure I like the beam pattern they put out I also found out the y do not work with the ipf h4 wiring harness I haveWhy are you on the fence about them?
Just placed my order and they will be here Saturday! Thank's Chris and Jerry as it was the two of you that convinced me to go with these for many considering factors.
Post a pic when you install! I want to order mine soon as well. and I am debating on blacking out my bezels and wheels to match.... Hmmm.... decisions to make.Just placed my order and they will be here Saturday! Thank's Chris and Jerry as it was the two of you that convinced me to go with these for many considering factors.
I believe no one has answered you because in the states, we do not have the parking/accessory light in our headlights like you do. If you need that light, you can wire something else up.i bought a similar pair from ebay. But they dont have a parking/accessory light. Did anyone else run into this issue? if so any solution to it?
I have the "Rubber" stubby bumper end caps on order and should get them this week. Here's what they look like.I like the color on your Jeep and nice lights. You should get some Mopar bumper end caps. Your number will look finished with them.
https://www.amazon.com/dp/B004TADG7Q/?tag=wranglerorg-20
I had the same issue. I ended up using a small screwdriver to separate the small solder joint on the trim rings; was able to get the trim rings seated properly that way.Did anyone have trouble getting the bezel that holds in the light around the new LED? Mine doesnt want to seat all the way on. It's quite possible that I r dum and missing something right in front of me.
Thanks
Great, thanks!I had the same issue. I ended up using a small screwdriver to separate the small solder joint on the trim rings; was able to get the trim rings seated properly that way.
