TJ Fest 2021
Replacement struts for hardtop rear glass?
psrivats
OR, USA
The struts that hold the rear hardtop window open don't work as they used to in my TJ. I want to replace them with new ones. Is there a recommended/liked brand for these?
mushdogs
Plain. WA
Reactions: rubicube
psrivats
psrivats
OR, USA
Are the OEM struts not an option you are comsidering?
Did not know you could still get OEM for our TJs. Where can I find them? Is there a difference in quality between OEM and aftermarket for these struts?
Edit: can someone confirm if this is the right part#? 55076310AD
toximus
TJ Expert
Northern WI
55076310AD is correct. I went with OEM when I replaced my wife's. Summit Racing carries the part too.
Reactions: psrivats
tworley
Bent Currie Club
Morrison, CO
I used the Amazon version too. For the short time I had the hardtop they worked, took a little effort to get them to close
Reactions: rubicube
psrivats
psrivats
OR, USA
Thanks. When I search for the OEM part on Summit, is the listing for 1 strut or a pair? I'm hoping it's sold as a set.
toximus
TJ Expert
Northern WI
Reactions: psrivats
psrivats
psrivats
OR, USA
Roadhawg011
South Africa
Does anybody know what the stock force on these struts should be?
I *think* they need to be 145N (33lbs or so) but not sure.
