Replacing Bleed Screws
Strawberry Bill
Harrisburg AR
I was going to bleed brakes today and found all 4 were clogged and fluid would only drain from threads. Decided to replace all 4 and was wondering if any brand is better than other. Crown and Dorman are available locally
Dorman sells a package of two at O'Reilly for less than $4. That's probably what I'm going to do unless @mrblaine has any other suggestions. Whatever directions he points you is the right direction. I bleed my brakes the old fashioned way so speed bleeders aren't too useful.
Dorman 13901 for stock front and rear.
SpeedBleeders can allow air to leak past the threads.
